How do I enable access to Developer Options? The standard method of tapping the build version doesn’t work, and I can’t find an option to enable it in Factory Mode.
Settings > Car settings > Tap Factory settings > Type adbon and hit enter. This will enable developer settings, which is located in the "About" tab of the Android settings. Keep in mind that developer mode will be disabled again after a reboot and you would have to enable it again when you want to change a setting. Changes to animation speed, etc. remain changed after reboot.
Thank you very much, it works. I couldn't figure out this method myself.
Best regards.
