How to Fix Time Zone Issues
  • If your device is displaying the wrong local time even though the time zone is set to "USA" or "China," please follow the steps below to manually correct it.
    Solution 1: Manually Set Home Time Zone
    1. On the home screen, click the time display to enter the "Clock Settings" page.
    2. Tap the three dots (⋮) in the top-right corner and select "More Settings."
    3. Scroll down to "Home Time zone" and manually select your current city/region.
    4. Return to the home screen to check if the time is now correct.
    Solution 2: Enable Automatic Time Update (Recommended)
    If you prefer automatic time synchronization:
    1. Go to Settings > System > Date & Time.
    2. Turn on "GPS automatic update time" (or "Automatic date & time").
    This should resolve the time zone issue. If the problem persists, please try restarting your device.
