vivid rom from 08/2023 doesn't support f2fs?
  • Vivid 10 Version: Make Sure your unit is PX6 Andorid 10
    telenav_vivid_rk3399_10.0_ota(20230801)
    I have switched to the last vivid rom, but my usb stick doesn't work. It is formated as f2fs and worked in the HA3_rk3399_10.0_ota(20230803)  version. Can you fix it in the last vivid rom?
    Thanks Micha
  • @Micha Icke We would like to tell you that the firmware files should in Home directory Formatted USB disk , FAT32 not F2FS. We are wondering if you have other USB disk or SD card.
  • No, you missunderstood. The new rom flashed I have done with vfat.
    But my music on a USB stick is formated in f2fs. It is more stable than vfat.
    the stick works in the standard rom, but not on vivid.
    Micha
  • @Micha Icke Hi there, we are wondering if you have tried other USB port as we have dual and single USB cable. If no, please kindly tried both of them, we want to exclude the cable related issue. If still no luck, we are wondering if you there is other error notification that you mean the new firmware can not support f2fs formated music, we can forward to our programmer and seek for further assistance.
  • hm, the vivid rom doesn't accept my USB stick in vfat too.
    Have formated the stick in the dasaita unit, will test on my pc if it work.
    My pc is debian linux.
    Micha
  • So, my USB device is now working, formated by the PX6 with exfat.
    So it seems that wether f2fs nor vfat are working.
    Es scheint also, dass weder f2fs noch vfat funktionieren.
