This was mounted under the radio on the same bracket as the original radio. Is it to be removed or plugged back in. I have a 2015 Accord LX installed G12 unit.
If your car only has the upper screen and the hand free buttons on the steering control could not work, please kindly confirm if there is an hand free plug under the dashboard and contact with our customer service for help.
Yes my car has only an upper screen, however the plug that was plugged into this Honda accessory box is used in the wire harness supplied with my Dasaita units wire harness. So should I unplug it from my Dasaita harness and reconnect it to this box I removed?
@Rudy Fierro Hi there, we have not received any reply or feedback about this accessory that you provided. You said that it has a plug, would you kindly show us the socket of it and which plug that you connected?
@Rudy FierroI just installed this unit two days ago, and I was wondering the same. I believe this is the Active Noise Cancellation Module.
You said the plug for this has a corresponding connection to the CB077 harness? On my end, I don't have any connectors leftover that would allow me to plug the ANC module into my Dasaita harness.
If possible, can you send a screenshot of what you got it plugged into? Thanks.
@Support Dasaita I have been not able to get any signal on the iMid / Upper screen. Would you advice me what should be wrong ? Do I need to review a particular connection, pin, etc. or it is something that I need to review in the unit settings?
