VEHICLE COMPATIBILITY: Toyota Tundra 2007 2008 2009 2010 2011 2012 2013
Model: HA5440(DYX004) HA5440H(DYX004+CB005-1) HA5440H2(CB004)
Will CB004 work with a 2020 Toyota Sequoia with JBL? Here's a pic of the front and back of the head unit. I'm told by folks at the Dasaita Amazon storefront and Dasaita chat that it will but I am having problems making the connections as the connectors don't fit. Please help.
@John Donnelly We would like to tell you that your car fits CB047, you could see the plug of CB047 below. Do you mean that you have already placed an order but the cable is not compatible? If so, we are wondering if you could try to change it to an suitable cable and we would like to tell send the listing to you.
Hello- The screen went black on my newly installed Head unit after about a month of run time. Noticed when turning on the headlight that the row of buttons on HU do turn on so the unit does have power. Any way to restore/reboot the Unit or should this be Returned for an exchange? Also If I have to replace the Unit will I get a replacement screen protector as well?
Also, Just realized this is for a 2015 Tundra and I'm in the wrong Group Forum :)
Thanks,
Al
@Al Olivares Please kindly let us know your order number so that we could record and offer you instruction.
I am replacing the Toyota OEM Navigation Stereo E7030 with the G13 in my 2011 Toyota Tundra SR5. This radio is the Non-JBL version. Will you place confirm which harness I should use and the CANBUS setting I should use? Thank you.
@ZCline
For further confirmation, please provide the whole dash front side photo and back side photo of OEM stereo to our email.
Alternatively, please simply confirm whether it is the same as our attached example picture.
✉️Email: team@dasaita.com
@Support Dasaita Thanks for the quick reply. This is the rear of the head unit. I've also attached a photo of the model in case someone else has the same question in the future.
@ZCline
If possible, could you please also send the whole dash front side picture?
I installed the HA2272 unit in my 2013 Tundra. The oem head unit was non-JBL but did have a factory reverse camera. The reverse camera video is not working now. How can I fix this? Thank you.
@Jacob Gooding
DYX004-1 cable in the parcel supports factory reverse camera.
Please find the yellow cam in for the audio output&cam in cable to connect.
