Toyota 4runner Limited 2016 missing canbus
  • 12/14/2023
    Hey, I received my new radio for my 2016 4runner, BUT my harness (CB004-X) that I needed is missing the can-bus module, The other harnesses have them (RPS-TY-102) and (RPY-TY-001) can you send me one right away???
    Can I install the radio without it until you send me the needed the can-bus module for my 2016 4Runner Limited and still work for the most part?  Will the backup camera still work without until I get it?
    2016 4Runner Limited with JVC
    Order: SP-DA4348
    Radio:
    Dasaita Android 12 Car Stereo for Toyota 4Runner 2010-2022 Silver Wireless Carplay & Android Auto Car Radio | Qualcomm 665 | 9" QLED Screen | Wifi+4G LTE | 4G+64G/8G+256G | DSP Head Unit | Optical Output
    James V
  • @James Varney We would like to tell you that CB004 and CB047 are sharing the same canbus. In this case, if the canbus box is connected with the CB047 harnesses, you could remove it and connect it to the CB004-X.
  • Thanks support for your fast response!!!  That makes since.
  • @James Varney hi there,
    Were you able to do this? I and the same issue where the CANBUS modules was missing from my harness (but the other two harnesses had one).  Did you just take it off and plug it in somewhere else?
  • @matt f Sorry for the late reply, I am sure you have it by now,  that that is correct, removed the CB047 and connected to the needed harness
  • @matt f yes,there is a label on each harness,CB004 and the CB047 using same canbus
