I have the dasaita vivid 11 for a 2017 toyota tundra.
the camera switches when I put the car in reverse but I see a yellow triangle with an exclamation mark.
does this mean something is broken? I can't change anything else about it?
@sebas konijn It seems that the camera cable is not well placed, please kindly let us know your model so that we could send you the connection instruction to you directly.
@sebas konijn Hi there, we assume your wirings is incorrect. Here is the instruction.
Please make sure that if your car is compatible with NO.4, you need to connect the right camera plug with cam vin. Meanwhile, make sure the pinout of all the plug is in good condition and not bent.
Postovani, molim za pomoc! kupio sam Dasaitu Vivid 11 HA5226+cb011 od Forgenta i ne mogu da dobijem pomoc da bih zavrsio instalaciju . U pitanju je montiranje rikverc kamere sa trzista (Forgent) . Spojio sam video kabal 6m sa kablom za napajanje kamere, drugi kraj video kabla sam spojio sa AUX V IN, ali mali crveni kabal ne znam sa kojim kablom da spojim. Sa narandzastim kablom na kojem je oznaka BACK ili sa PINK kablom koji ide iz Porta za napajanje. Na etiketi na radiju pise da je Reverse kabal broj 2 narandzasti sa oznakom BACK ali u njemu nema napona.
Gde da ukljucim zadnju kameru u Fabrickim podesavanjima ili u aplikaciji kamere.
@Bozo Gilic It seems that your wirings is incorrect, have you followed the instruction that we sent above. If no luck, please kindly send us a few photos of the wiring on the back side so that we could diagnose and further assist you in solving the problem.
I have the G13 for 2014 Corolla. I have the camera plugged in to No. 4, but the camera is not working. I get the yellow tangle. How do you switch the 4 with the 4-1 plug?
