rear view camera not working
  • I have the same issue on 2006 Honda Civic. When i put the car in reverse, Camera does not work properly. At first is shows a glitch black and white image of the back and then it goes into a yellow triangle with an exclamation mark.
    Camera Unit: AHD 1080P  Reverse/Front Rear View Camera
    HeadUnit: Dasaita 10" Android 11 Car Stero
  • @prisurf
    Thanks for your message.
    If it goes into a yellow triangle with an exclamation mark when you put the car in reverse, it's most likely a wiring error.
    Here enclosed the aftermarket rear view camera connection for your reference.
    Please make sure that you have connected properly.
  • 1
  • 2 / 2
