@Ryan Resendez Please kindly go to Settings > About Machine and send us your current Build Number and MCU version, we would like to check if your update is successful or not.
@Support Dasaita Hello. I've the same problem with zlink
My unit is: px6 max6 model - rk3399 with Android 10
Knel version 4.19.111+ #228 Tue Nov 2 10:55:04 CST 2021
Mcu MTCE_HA_3.78
I'm sure that my unit have apple car play/android auto unit because I've already use it with android 9 with my iphone usb connection but now, after updates, is deactiveted and says "MFI not found". how is it possible? It's like chip is desapperead. In factory settings the voice "zlink" is activated and I've already tried any solution.
Please help!
@Alex Murphy Please kindly let us know your order number or the SKU of your stereo, so that we could locate more detail and give you instruction.
Same issue need activation code or QR for zlink
Hi i have the same problem
@Support Dasaita I am having the same issue. Can you reactivate my code?
@Luca Leonardi
@Luca Leonardi
Could you please go to Settings>About machine and provide the following version information:
@Kaylee Barton
Build Number: AJ_2023.08.19.10_3_2224
MCU Version: CVD1810-WJ_22.10.24_399
Electronic QR Code: 1581133230f882acb
Hi Kaylee,
Did you try to make the unit connected to the internet to active it?
If you already done but no luck,please send the QR code to us,so that we could help you.Thanks.
@Support Dasaita I'm having the same problem.
@ANDRES GONZALEZ @Kaylee Barton
We couldn't active the code,please send the order details so that we could better confirm.
@Support Dasaita I've tried connecting to 3 different wifi and hotspot and can't get it to auto activate and rebooted
@Brian Stewart
Hi Brian,
Please provide the order details to us,so that we could bette confirm.Thank you.
@Support Dasaita Hola, dispongo de un sistema px6 Max 10 en nissan x Trail, me ha dejado de funcionar zlink de forma inalámbrica por bluetooth, la versión MCU instalada es las MTCE_HA_V3.78_1 de mayo de 2021. Ya he probado todas las opciones de iniciar la conexión desde el principio eliminando el dispositivo guardado y sigue sin funcionar, agradecería ayuda al respecto. Muchas gracias de antemano. Saludos.
@Brian Stewart As per this picture, this auto activate is not from Dasaita.
@Juan de Dios Rodríguez Thank you for your details. Please also send the QR code to us
