When i turn the car on sometimes the unit works and then sometimes it dosent.
@edwin villegas Please go to update the firmware and MCU.
4.12MCU: https://www.dropbox.com/scl/fi/0ksub1bba94rm8ttxfikv/hmcu.img?rlkey=bx8j6osl48uf8nxr6qwbb8zm
the mcu link isnt working
This happens to me from time to time on my Android 12 unit. Sometimes after a few minutes it will power on.
@Michael Uribe
Here is the latest MCU(4.12):
@Michael Uribe Do you mean that your head unit will power off and on sometimes, please let us know your current MCU and Build Number.
@Support Dasaita I mean that my head unit will sometimes not power on right away. Sometimes it takes about 5 to 10 minutes for it to power on. This normally happens if the car has been turned off for only a short amount of time. Another related problem is the head unit always completely powers off when I turn the car off. It doesn't matter what setting I choose in the "Delay when ACC off" option. I didn't have this problem until I switched to the Vivid version of Android 12. Below is my MCU and Build Number.
MCU: MTCH_HA4Z_V4.12b_1 Apr 19 2024 10:04:11
Build Number: QCM6125 12 S10A_123 eng.hct3.20240410.094237 NA
@edwin villegas Can you update finally, we've check the link and it seems OK?
