i got the same problem and tried your update file without success. Any suggestions?
Second question: where can I disable fast boot in scout? I think the head unit draws to much current in standby and since its a RV which is not used daily, I dont want to charge the battery all the time..
@Thomas Makro It seems that your update is not successful, could you please go to Settings > About Machine and send us your current Build Number and MCU version.
Besides, as to the fastboot, could you please go to Settings > Car > Extra Settings > Shut down delay and then choose any option other than Auto Sleep. Auto Sleep is equal to the Fastboot.
Ah, found it, thanks! Here are build number and MCU.
@Thomas Makro
telenav_vivid_rk3399_11.0_ota(20240604)
https://www.dropbox.com/scl/fi/1clw6dqa9zmxfr717uuwh/update.zip?rlkey=ltfea919b8ytclpytaqfjlser&dl=0
Please update the firmware under the following instruction.
thank you for your effort but the problem is still the same.
@Thomas Makro We are wondering if you could record a video to show us which file that you put into the USB and then record the whole process that you proceed the update. We will diagnose accordingly. Your cooperation will be appreciated.
@Thomas Makro Any update of the video? Your understanding and cooperation will be appreciated. We could better diagnose accordingly.
sorry not yet. I will make a short video in the next days.
@Thomas Makro
No problem, please provide the video at your convenience.
@Jason Man ciao, vorrei risolvere anche io questo problema che ho avuto dopo l'aggiornamento.. preferivo il navigatore a sinistra.. come posso risolvere?
@Support Dasaita ciao , dopo l'ultimo aggiornamento non ho più il navigatore a sinistra dello schermo... Esiste un impostazione per rimettere sulla schermata iniziale il navigatore a sinistra dello schermo..
