I purchased the g13 2010-2019 head unit. The original oem brackets on my JBL head unit do not match any of the installation pictures. I received two recantuglar mounting plates with the kit. Neither of them work with the oem brackets I have, I have a gap of ~12mm to the dash mounting point.
Photo of my oem bracket below. Please advise if there is a differnt mounting bracket kit I need to make these work.
@Jodi Moore
Hi Jodi,
Sorry for that you’ve had this bad experience,actually it is the first time that we've encountered this kind of brackets,it may not suitable.we have sent it to the engineer to look into this,we will get back to you when we get response.
a gap of ~12mm,if possible to DIY the barckets to get this thing work?
I'm having the same issue, the 2011 toyota 4runner brackets doesnt go well with the Dasaita head unit. There is a gap between the bracket and the mounting point while trying to screw it in.
Another issue I'm seeing is that the black clip on the OEM head unit cannot be transferred over to the Dasita one as the screw hole position doesn't match.
On a side note, while hooking up the connectors my steering wheel panel switches are not getting power. They are not lighting as they used to do with OEM unit, and on Dasaita key mapping settings they are not registered either
@Rohith Pokattel
Regarding to brackets issue, we have forwarded it to our engineer for developing the new one.
Any updates, we will inform you further.
We'd like to know if it is the steering wheel button backlighting cannot light.
@Support Dasaita i'm having the exact same issues. it does not fit in the oem opening. what are you going to do about it. also, i have tried 3 times for you to send me a return label so i can get the core back to you and get my warranty started. what's up??
@JOHN ALLISONHi John,
To ensure the specific solution for your car stereo,please provide us with your Order details(Including Order Number&Unit model&Version)
@Ansel Robinson
May we have the below information?
1. A picture of your OEM Bracket.
2. A picture of your OEM unit .
3. Special year for your car.
Thanks for your cooperation.
