G13. Car settings dont work.
  • Everything from the Car Interface to the G13 works (Door Open images, Rear Camera, AirCon etc.) apart from the car settings page using the Contol Settings App. None of the settigns display values change with the increase/decrease arrows.
    I think it might be something to do with the CanBus settigns ? But I dont know what to set it to.  Can Dasaita Support please help?
    the Car is a Mitsubishi Outlander 3 2014 model. I purchased the Dasaita unit driectly from the Dasaita website.
  • The control Settings App is related with the Canbus selected
    Do you have the CanBus correctly configured?
    On the Factory Settings (password=126) you can check which CanBus is configured.
  • @Iker Gomez    Yes, thats correct... thats why I wrote "I think it might be something to do with the CanBus settings ? But I dont know what to set it to."
  • I think @Support Dasaita  must give you specific instructions according to your PurchaseOrder, as they know which Canbus sent to you.
  • @Clive Hawnt
    Is it the case that all the settings in the control settings are not working?
    For your car, the CANBUS Select is NO.57 .
    Please go Settings>Car>Factory Settings:126>Canbus .
    If it is not luck,please provide your order ID to us.
  • @Support Dasaita Thank you for your reply. None of the screen items change but I know something is changing as I accidently changed the windscreen wipers BUT the disaply doesnt show this.  I'll try the CANBUS setting ands let you know.
    Order ID is  SP-DA7327
  • @Clive Hawnt  No problem,thank you for your time.
  • @Support Dasaita This didnt solve the problem, I already have CANBUS already set to 57.
    in the screenshot I posted above None of the items  change when I click on the <> controls, BUT I know something changes as I tried it  on the windscreen wipers settings and they changed.
  • @Clive Hawnt
    The functions are changing  after you click on the <> controls,  but the car settings page remains unchanged . Is this issue?
    If yes, could you send a video to clearly present this issue to our email ? support@dasaita.com
    Thank you very much.
