Auto Front Camera Activation Displays Inverted Image
  • I have installed:
    Dasaita Android 13 Car Stereo for Toyota Tacoma 2016-2022 Wireless Carplay & Android Auto Car Radio|Qualcomm 665|11.6"QLED Screen|Wifi+4G LTE|8+256G|DTS Head Unit|Optical Output
    Vehicle: 17 Tacoma SR5 - Front AHD 1080P Front Camera- Rear Factory Camera
    The issue I’m experiencing occurs when I enable the feature to automatically switch to the front camera after shifting out of reverse. The image displayed is flipped left-to-right, showing the opposite of what’s actually in front of the vehicle.
    However, if I manually activate the front camera using the F-Cam button, the image displays correctly, and I can toggle between the front and rear views without any issues. When using the F-Cam button, there is a
    <- -> toggle button on the far right of the screen, this can invert the screen view. This button is not present when the camera is activated automatically after shifting out of reverse.
    How can I get the image to display properly when the “Show Front Camera After Shifting Out of Reverse” feature is turned on?
  • @Red Tacoma
    For this issue, let us try to update/
    No worries, we'll try our best to help you.
  • Hi, try the following: Go to Android Settings/Vehicle/Additional Settings/Rear View Mirror Level and disable it. In my case, the rear view mirror level only affects the rear camera. For the front camera, I can control the right and left sides of the image using the two arrows icon. In your case, it seems the rear view mirror level affects both cameras simultaneously. I hope this helps.
  • @José Guillermo Huertas Lancheros
    Thanks you for sharing details so much
  • I sent 2 msgs with image and nothing shows in the thread.
  • @Support Dasaita  can you check the image approvals for my images
  • Here is the text extracted from the image
    Model
    QCM6125
    Android version
    13
    Kernel version
    4.14.190
    #179Tue Mar11 10:49:15CST 2025
    Build number
    QCM6125 13S10A_123 eng.hct.20250311.103730 NA
    MCU version
    MTCHSHA4Z_V4.16b_1
    Apr 25 2025 15:22:41
  • @Red Tacoma
    Dear customer,
    ②4.16g MCU:
    https://www.dropbox.com/scl/fi/61d69lkomwkf005tvgigb/hmcu.img?rlkey=emrb91895qodihn8f9ih27e7x&dl=0
    2.Format the USB drive(FAT32 Format)before copying the Update.zip & hmcu.img file to it, then insert it to the USB cable,and it will pop out the firmware updating tips on the screen.
  • The firmware update fix the image filp  issue, thank you!
  • @Red Tacoma
    You're welcome.
    If possible,could you leave a review of our customer service via your order?Your comment really matters and helps to keep us motivated.
