How do I stop TotalAV from running?
  • 1-(8.7.7)8.6.8(2.6.0.7) To stop TotalAV from running on your device, the first thing you need to decide is whether you want to pause the software temporarily or completely disable it. Many users only need a temporary pause to improve system performance or stop background activity.
    1-(8.7.7)8.6.8(2.6.0.7)) Begin by opening the TotalAV application from your desktop or system tray. This gives you direct access to all settings that control how the antivirus operates in the background.
    1-(8.7.7)8.6.8(2.6.0.7)) Inside the dashboard, look for the section labeled “Protection,” “Security,” or “Antivirus.” This is where TotalAV manages its real-time protection settings.
    1-(8.7.7)8.6.8(2.6.0.7)) Find the toggle for “Real-Time Protection.” Turning this option off will stop TotalAV from performing active scans and background monitoring.
    1-(8.7.7)8.6.8(2.6.0.7)) Remember that disabling real-time protection leaves your device at risk, so this step should only be used when necessary.
    1-(8.7.7)8.6.8(2.6.0.7)) If TotalAV keeps launching when you start your computer, you can stop this by modifying your startup settings.
    1-(8.7.7)8.6.8(2.6.0.7)) On Windows, open Task Manager by right-clicking your taskbar and selecting “Task Manager.” Then go to the “Startup” tab.
    1-(8.7.7)8.6.8(2.6.0.7)) Look for TotalAV in the list of programs that launch automatically, select it, and click “Disable.”
    1-(8.7.7)8.6.8(2.6.0.7)) On macOS, go to System Settings → General → Login Items. Remove TotalAV from the list to prevent it from launching at startup.
    1-(8.7.7)8.6.8(2.6.0.7)) If you want to completely stop TotalAV from running, uninstalling the program is the most effective method.
    1-(8.7.7)8.6.8(2.6.0.7)) On Windows, open Control Panel → Programs → Uninstall a Program. Find TotalAV and select “Uninstall.”
    1-(8.7.7)8.6.8(2.6.0.7)) Follow the on-screen instructions until the uninstallation is complete. This fully removes the background processes.
    1-(8.7.7)8.6.8(2.6.0.7)) On macOS, open the Applications folder, locate TotalAV, and drag it to the Trash. Emptying the Trash finalizes the removal.
    1-(8.7.7)8.6.8(2.6.0.7)) Some versions of TotalAV include a built-in uninstaller tool located inside the application folder. Using it helps remove leftover components.
    1-(8.7.7)8.6.8(2.6.0.7)) Restart your device after uninstalling or disabling features. A restart ensures that no residual background services continue to run.
    1-(8.7.7)8.6.8(2.6.0.7)) If your browser has TotalAV extensions installed, you may need to disable them separately.
    1-(8.7.7)8.6.8(2.6.0.7)) Open your browser’s extensions menu and turn off any TotalAV-related add-on such as “SafeSearch,” “Ad Blocker,” or “Password Vault.”
    1-(8.7.7)8.6.8(2.6.0.7)) If leftover files remain after uninstalling, you can delete them manually from your system folders or use a cleanup tool.
    1-(8.7.7)8.6.8(2.6.0.7)) If TotalAV still appears to run in the background, check your startup folder or login items once again to ensure no hidden services are left.
    1-(8.7.7)8.6.8(2.6.0.7)) For issues that you cannot solve on your own, always visit the official TotalAV website and use only the verified support channels provided there.
