Firmware Upgrade
  • Looking through the other posts here I would like to upgrade the firmware/MCU on the unit.. One of the biggest issues is that the screen birghtness doesn't change very much from min to max. It does go into night mode when the headlights are on but the screen is still very bright. There was another post on here about that same issue. And the last post indicated they did a firmware upgrade. Attached is a screenshot of the current versions. Can I get links to the most recent MCU and firmware versions. Also Is the G13 fiumware and Vivid 13 firmware interchangable on the same hardware? Can I flash between the two and see which one works better?
  • @Chris Hand
    We are wondering if you could try the troubleshooting in the following topic:
    https://www.dasaita.com/community/forum/topic/212238/screen-brightness-settings-and-adjustment-solution
