Honda Accord 2013 Slow Steering Wheel Controls
  • I recently purchased the Android13 stereo model HA5206H-G13-CP-HD-Plus-4+ANT002.
    And the truth is, the steering wheel controls are working: volume up, volume down, back, next track, and source.
    The only thing I've noticed is a slight lag sometimes; it probably takes a second or two to register the request. I've also noticed that sometimes the steering wheel command simply doesn't register.
    Is there anything that can be done to improve performance?
    It's not impossible to use, but when you're used to the factory stereo, which is very responsive and fast with the steering wheel controls, it might be a bit of a shock.
    @Support Dasaita, can you give me any advice?
    Best Regards
  • @Alex Soria
    Could you send a video of showing the issue for steering wheel controls?
  • Hi,
    I have posted a couple of times, links to the videos. But it says that the post needs to be aproved. Can you help me with that, so you can see the videos?
    Regards
