Airbag system error displayed on the dashboard
  • If the airbag system error shows on the dashboard,please follow these steps:
    1. Disconnect the negative battery terminal for 10 minutes, then check the AC control panel is connected properly.
    2. Use an OBD2 scanner to read and clear the airbag fault codes.
    3. If your unit is equipped with a Canbus cable, disconnect the Canbus and check if the error remains.
