I recently installed the Dasaita headunit in my 2015 Honda Accord LX. On a sunny day (around 27 degrees C), I saw the head unit become unresponsive. It appeared to be getting phantom clicks. I think this is due to the heat since after running cabin cooling for a few minutes the issue subsided. Is there any work around? Is it advisable to install a small fan on the back of the unit to dump heat out of it?
@bralesito.seamons Please go to Settings > About machine and send us a screenshot about the current Build Number and MCU version.
Also, please note, that in the settings I saw a "fan" mentioned. Does this refer to a fan built into the headunit? Thanks!
Can you share a bit more info. What is the advantage to this firmware and MCU. Additionally can you followup on my comment about the fan? Thanks!
Following up here, thanks!
@bralesito.seamons We regret to inform you that our current hardware design does not support aftermarket fan installation. The motherboard does not have a dedicated fan header or power output for such a modification, and installing an external fan may interfere with normal operation or even void the warranty.
I experienced the same situation in my Dasaita Max10 PX6 for my Mazda CX5, if you want we can contact you privately, if I publish the improvement that I have made by installing a fan the Dasaita team will remove it. I installed an AB1212HX controlled by a PCB, I control RPM by Temperature, the Unit works exceptionally and very fluidly, with Spotify, IGO Navigation, Application Updates and more applications simultaneously; The maximum temperature reached is 53ºC
