ELM327 OBD II adapters cannot read the tire pressure data, though they are available data on the OBD II. The only adapter that I've found that can is the OBDLink MX+ adapter. However, the OBDLink MX+ will NOT work directly with the Dasaita G13. Dasaita's implementation of the Bluetooth stack will not allow the G13 to pair iwth the MX+. The G13 also will not recognize a third-party Bluetooth adapter plugged in to a G13 USB jack. I discovered this after several days of trouble shooting, trying to monitor tire pressures in my 2007 Camry.
However, the MX+ WILL work just fine if it's installed on a phone. From within the OBDlink app on your phone, download and install the enhancement package for Toyota. Follow the instructions for monitoring tire pressure and tire temperature. From within the OBDLink app, set up the app to display each as digital gauges.
Then, connect via Android Auto or Carplay on your G13. Select OBDLink from with in Android Auto or Carplay, select the appropriate display, and you're good to go. The car will continue to monitors its internal sensors and sound an alarm in an under- or over-pressure situation. You can then check then use the OBDLink software in Android Auto/Carlink (or direct from your phone) to check the pressures and temperatures of each tire.
NOTE: The Toyota internal sensors do not transmit a signal continuously, so you may have to wait a few minutes before OBDLink shows the live reading.
I don't know why Dasaita won't consider a firmware revision to the G13 that will permit Dasaita's TPMS app to read the Toyota's internal TPMS sensors, as it works just fine with Dasaita's external sensors. The only difference is the frequency and the protocol. However, I've seen no indication that Dasaita has any interest in changing it's sensor hardware (the external small unit that plugs into a USB port) to support Toyota's internal sensors. I've seen that Dasaita is now selling its own internal sensors that can work with the Dasaita's TPMS app. Were it not for the significant cost of changing them out for the factory sensors, they would be a good solution.
