How to change the default Music Player on Max10.
  • Hi there, I noticed that you do allow an option on the Max10 PX6 unit to change the default navigation app, is there also a way to change the default music player app?  If not, can you please consider that as an option in the next firmware upgrade?  Thank you
  • Hi, Gregory Whitman,
    Pls reply us ASAP, thanks.
  • @Gregory WhitmanHi Gregory,
    did you find a solution for change the default Music Player on Max10?
    regards
    Birgit
  • Unfortunately, Max 10 does not allow the user to change the default music app. I upgraded to Vivid 10 which allows the user to choose which music player app opens when the touch panel music button is pressed. Vivid is much more modern and cleaner looking. Search youtube for "upgrade dasaita max 10 to vivid 10" and follow the instructions. The video contains a link to download the vivid 10 firmware.
