Bluetooth, wifi and clock problems same as others
  • Hi, I am also having issues with no bluetooth and china time not being able to be changed or at least stay after being changed.  This is an android 11 stereo for a nissan rogue.  right now the time won't stay, bluetooth will not recognize anything, nor will the wifi turn on, it initially did when I installed it, now nothing
    My version is rk3566
    Thanks in advance
    John C.
  • As tried to configure it in Factory Settings, from there you can change the Bloutud
  • @John Covert Hey! I got the exact same issue as you for my Qashqai (Rogue Sport for americans)
    heres the update you need to install in order to solve the problem:
    https://www.dropbox.com/s/om4kil7nt1lvx6u/HA3_rk3566_11.0_20220214_ota.rar?dl=0
    however, for me the problem as been continuing but it connects more often and the timezone is ok now. Uncompress the file, install on a usb and connect it to the car. I hope the issue will be soon fully solved!
