My unit 4G/Wifi option with reverse cam before stuck on black screen of death on boot was in the past:
QCM6125 12 S10A_123 eng.hct.20230406.105233 EAU
MCU: HCTGQ_HCT_V4.03_1
Apr 4 2023 13:34:20
I managed to enter to recovery mode and becouse lack of original software backup I put there:
gmcu.img V4.12 first and update zst27_sc138_12_(20240513).zip ( I wiped flash of course).
MCU: HCTGQ_HCT_V4.12_1
Mar 13 2024 09:44:14
QCM6125 12 S10A_123 eng.hct3.20240513.152630W
The unit revived but now I don't have WiFi - the option is available in menu, but after I put it to on app suspends a little and nothing happens. Tried also gmcu.img V4.13 and gmcu.img V4.54
The second observation - no other update than zst27_sc138_12_(20240513).zip boots correctly. Other G12's updates stop on the launcher's start and reset the unit. I always have to return to zst27_sc138_12_(20240513).zip to boot radio to normal operation, but there is no possible to execute command WiFi to on.(GUI can do it but hardware is not).
The BT chip is FSC-BT825B V1.1 and in the factory settings works under FSC_BW124 setting option. Tries other BT options, but it didn't help for WiFi.
IF I understand well the Wifi is in Fibocom unit becouse there is only antenna output. How to revive the wifi to have internet connectivity? Which firmware or MCU should be updated?
Dear Mik,
①G12 Version:Make Sure your unit is QCM6125 Andorid 12
zst27_sc138_12_G12(20241126)
https://www.dropbox.com/scl/fi/7v62tizo1rxwhqxgsjw7b/update.zip?rlkey=x8lml0ia4ya1xdxtvje9fboqa&dl=0
②4.12b MCU
2.Format the USB drive before copying the Update.zip & hmcu.img file to it, then insert it to the USB cable,and it will pop out the firmware updating tips on the screen.
@Support Dasaita I have MCU on gmcu.img - is it safe to update from hmcu.img? How to do it, because system update searches for gmcu.img?
@Mik Po Hi Mik,the MCU can be update to the latest,please don't power off the car when proceed the updating.
But MCU You linked is for HA4Z (hmcu.img) and it not compatible with my unit based on gmcu.img - it cannot be flashed (radio unit says it is not compatible).
@Mik Po Hi Mik,
To ensure the specific solution for your car stereo,please provide us with your Order details(Including Order Number&Unit model&Version).
please go to Settings>About machine and provide a pic of showing following version information:
2.A clear photo of the stereo's MCU version.Thank you for your time and cooperation in advance, we look forward to your reply.
