Just completed install of Dasaita Vivid11 in 2019 Rogue. 360 camera works correctly when in reverse. Cannot view the front or rear camera individually. I assume the wiring is correct since 360 works. Is there a setting or an app that's needed?
@Joe Shinault any resolution on this? I have the same issue.
@dasaita
@Dasaita Official@Chauncy Wilkins / @Joe Shinault
Im experiencing the same issue where the front camera works in the around view mode but can't access independently (while in drive for example).
Is there a solution for this issue?
