La última actualización no funciona bien, da un fallo de Bluetooth.
Deberían de mirarsela y arreglar el fallo, contra mas gente actualice más problemas saldrán.
Gracias
@Juan Perez you are right Juan. A bluetooth error (bluetooth app is not responding) is displayed constantly. I didn't notice any blietooth failure (bt is working well, calls & zlink work) but the error is bothering as you have to touch out of the error message window to remove it but it appears again after some minutes.
@Juan Perez @Iker Gomez Thank you for your kind remind, and our engineering and programmer are still looking into the issue. Once getting their reply, we will release new solution and to get the problem resolved. Meanwhile, we have removed the link of 0525 version and 0717 version as well.
@Iker Gomez Our engineer has already found the bug and released a new firmware for MAX10 while the other UI is still being programmed. Or we are wondering you can help us to upgrade your firmware to the max version, is your current head unit Android 10 or 11?
@Support Dasaita I am currently in A10. I am hoping vivid issues (like Google maps opening from the docked waze icon) could be resolved too with the latest vivid Rom
Yo actualmente tengo A10 y estoy con Vivid actualizacion 20230112
@Support Dasaita if you want share the link privately in order I could test it prior to publish
@Iker Gomez I‘ve sent the latest version to privately.
@Juan Perez Please update the vivid 10 firmware that we have fixed the bluetooth issue. Here is the link of the firmware package.(Make Sure your unit is PX6 Andorid 10 Version with vivid UI)
https://www.dropbox.com/scl/fi/aaqv1utd0wx0t2rl4kyeq/update.zip?rlkey=ria0tfcoxbcioqh2pb9z38tzg&dl=0
Hope you can feedback us if the problem can be resolved or not. Your cooperation will be appreciated.
Good afternoon. I have installed the update that you have given me and I have to say that for the moment it works well, nothing is wrong.
Let's see if it continues like this and I'll comment on it.
Thank you.
I did the upgrade as well and everything seems to be ok.
I hope the SCOUT OS is fixed next because I'm having the same bluetooth problem on that version.
Mark
