Jeg er kommet i samme problem som frank romsdahl. har også få sleete noget af Igo fra min Dasaita radio, da jeg opdatereden den til ny software. kort over Eropa er fint nok til mig
Tips: 1. Download above link via computer/laptop. Use the WinZip application to unzip the file "iGO-EU-2024Q2". 2. Copy the whole unzipped folder "iGO_Pal"(it contains multiple files) into USB drive. 3. Insert USB drive into the head unit via single/dual USB cable, copy "iGO_Pal" to unit's folder and tap "iGO.apk" to install it.
Hello, can you please send me the files I need to install iGO on my G13 Unit for Toyota Tacoma 2017? I'm in Canada. Does the American map pack cover Canada or is there a special Canadian version? Thank you.
Hi @Kent, the simplest and easiest thing you can do is download the IGO Navigation app from the Play Store to your Dasaita unit. Once downloaded, open it and go to the store menu; from there you can purchase the maps you want, in your case North America and Canada. Of course, it's a paid app, but you'll have a premium version.
