G12 new added function: Fiber Optical Audio Output for Enhanced Performance🎶
  • In addition to supporting Normal RCA output, it now includes an internal fiber optical interface.
    This enhancement allows the G12 to accommodate different types of plugs found in various car audio systems.
    By incorporating this feature, the G12 ensures that music is performed in an exceptional manner, regardless of the type of plug your car utilizes.
  • Hello, what is the audio sample rate coming from the optical output? Is it the same coming from the analog outputs?
    I am using the optical output and it produces a static hiss when playing sine frequencies around 8kHz and 12kHz. I have tested to make sure its not coming from the amplifier.
    Also, what filters/crossovers are built into the unit? There is a steep drop in output below 30Hz. Can that filter be turned off?
