Hi @Support Dasaita, where can I find a working link to download the Scout Maps APK? The one in the other firmware topic leads to a deleted file :(. Need it to get scout maps on the left panel on the homescreen.
@Support Dasaita i have tried other USB connectors and sticks but it is not possible to install
i have been able to install MAX10 without problems but vivid10 is still not possible
@Jesus Sancer Our technician said that you could redownload the file and then reboot the head unit to check if it works, we have a newer vivid10 firmware(20240126), please try for it.
https://www.dropbox.com/scl/fi/9whz1p3ovge2ga2g75m8x/update.zip?rlkey=n9yitv3tnx3vzgaixesru94s8&dl=0
@Thomas T Scout Maps APK is just for firmware released after Noverber 2023. And firmware after then has already pre-installed the Scout map yet. You could let us know if your firmware is vivid and go to About machine to send us your current version, we would like to check for you.
@Support Dasaita, I had it installed and it worked perfectly, but I uninstalled the Scout Nav app on accident and lost the map. I had the APK file already downloaded before, but also deleted it. So I know the APK already works đ
@Thomas T Here is the Scoutnav APK: https://www.dropbox.com/scl/fi/s5h60402afl53m9t8kfww/ScoutNav-production-arm64-v8a-release-2.2.21.0.6-signed.apk?rlkey=nxfsckpbyvomvqpdp6fyzakoe&dl=0
Introducing the latest Vivid11&Vivid12 firmware update! đđ Now featuring a new screen lock function, ensuring your privacy is protected when driving to the auto shop or anywhere else. Update now to enjoy this added feature!
Do you have an ETA on the next update release for VIVID 12 for Qualcomm6125
@ZAKI KADOURA We will release the next version of Vivid 12 within this month. Please kindly pay attention the our post about firmware release.
https://www.dasaita.com/community/forum/topic/36770/firmwares
G12(20240513) Fix:
Improved Call Quality
Audio Output Volume
@Support Dasaita Will this update also come to the Vivid firmware?
@Support Dasaita when is it available OTA?
does waze work?
@Michael Uribe We need more time to test the Vivid 12 version.
@K D OTA will be updated soon, if you want to update the firmware now, you could download from this link.
@Junior Cedeño Sure, you could download the maps from the Google Play Store.
@Support Dasaita yes, i noticed that on G12(20240513) Fix. Thanks. Any other improvements? Also, is there a link to list what update was made on a new firmware releases?
I'm having the same update problems. No matter which version of software I try, I get "installation aborted". This is for a PX6 running Android 10 for a 2016 Toyota 4Runner. I've tried Max10, Vivid10 and Vivid11. I've switched USB ports and also made sure nothing else was plugged in. I've also made sure that update.zip is the only file on the FAT32 formatted USB key. Help?
@ZAKI KADOURA
@Randy T Could you please send us a screenshot to show us what you have put into the USB?
