Exciting Update: OBDII Data Viewing Now Available on the G12!
  • OBDII Data Viewing Now Available on the G12!
    We are thrilled to announce a new feature on our navigation system that allows you to view OBD data using Torque directly on the navigation screen. This exciting update brings a whole new level of convenience and functionality to your driving experience.
    To use this feature, simply follow, please refer to the tutorial below.
    How to connect OBDII on G12
    With this new feature, you can easily monitor your vehicle's performance, diagnose any issues, and make informed decisions about your driving.
    Upgrade your driving experience with our latest update and enjoy the convenience of viewing OBD data directly on your navigation screen. Stay tuned for more exciting updates coming soon!
  • @Support Dasaita how do I confirm the usb is working? Files needing to download are not available.
  • Can I get transmission temperature from Torque? I have it connected and failing to see it. Anyway to upgrade to the pro version?
  • @Al Olivares you mean that you could not see the temperature or the OBD information on the stereo?
  • I'm not seeing option for transmission temperate on the toque app or any PID options to be able to add it. I'm getting other engine data though.
  • @Al Olivares We are wondering if you could shot a video to demonstrate the issue that you mentioned so that we could diagnose and give you instruction accordingly.
  • Hello- I was able locate the menu option in the torque app to add a new PID to read tranny temperature. I used the following settings that may help others in the forum.
    Code:
    5TH GEN 4RUNNER
    2ND GEN TACOMA
    2ND GEN TUNDRA (MY 2007-2021)
    PID: 2182
    Long Name : Transmission Fluid Pan Temperature
    Short Name : TT-Pan
    Min Value: -40
    Max Value: 350
    Scale Factor: 1
    Unit Type: F
    Equation: ((((A * 256) + B ) * (7/100)-400)/10)
    PID: 2182
    Long Name : Transmission Fluid Converter Temperature
    Short Name : TT-Conv
    Min Value: -40
    Max Value: 350
    Scale Factor: 1
    Unit Type: F
    Equation: ((((C * 256) + D ) * (7/100)-400)/10)
  • Torque is not available for download through google play for the G12. (Ive tried on unit and external browsers).  Any idea why? Did the developer block the G12?  Can you verify what the latest software/firmware update versions should be for a Doro QCM6125 (2014 Tundra) as of 1/2025.
  • @James Thompson
    Hi James,
    here is the OBD apk,download it on your laptop and copy to the USB drive,then insert it to the USB cable and go to the APKinstaller APP to install the Torque.
    https://www.dropbox.com/scl/fi/52fquqsk7pxhdmb8c82om/Torque_1.12.101.b1120101.apk?rlkey=l0cyi1myvsjqzlxxbebnkbdy1&e=1&dl=0
  • Thanks, I already did the same thing with version 1.12.99 and it worked great.  Any idea why I cant add the torque app to the home screen?
