On Wednesday June 4th, I installed the Dasaita G12 8G + 256GB unit in my 2018 Toyota SR5 4Runner, that I bought from Amazon.
Everything was going great, I even turned it on before putting it in its place in the dashboard but when I moved the unit closer to the dashboard it lost power. I turned the key engine on and off to see if that had any effect and nothing.
I measured the voltage coming out of the car connector to see if the problem originated there but no matter how much I moved thoswe cables the voltage was constant. So I concluded the problem was not related to the cables coming from the car.
Then I noticed that if I touched the harnesses the unit would start to power on, and sometimes it would boot completely and sometimes it would just light the LEDs on the sides of the screen and not boot completely. Sometimes it would do nothing.
For your reference I used the Harness marked as CB004 and the Canbus that came connected to the CB0047.
My conclusion is that there is something wrong with one or more cables and or connectors in the harness or the Canbus itself. Please provide me with a solution for this problem.
