Toyota C-HR + G13 + CB004 = Triangle Error OEM Backup Camea in Reverse Gear
    G13 does not want to switch on the Backup Camera when in Reverse Gear.
    I have just the black screen with Triangle Error in the middle.
    What i have checked so far:
    1. Camera works in F-Cam app
    2. Canbus is set to 8
    3. "Prohibit reverse" settings is not there in the "Other" Sub-Menu
    What else can i try?
  • F-Cam test:
    https:// ibb.co/TB7x3SN6
    https:// ibb.co/4ZghNn9y
    Reverse Gear error:
    https:// ibb.co/zWzR7QYR
    Canbus Settings:
    https:// ibb.co/WNWdRbn9
    Other Sub-Menu Settings - no "Prohibit reverse":
    https:// ibb.co/BK4f3JNR
    https:// ibb.co/gMqHwfWp
    https:// ibb.co/6cN9WnrD
    https:// ibb.co/xtyv3bFJ
    https:// ibb.co/xKSzCNQx
    One other thing, the written manual is confusing, showing some Vires that dont event exist:
    https:// ibb.co/nNVS4ncL
    https:// ibb.co/dsHTD83R
    I dont have that "BACK" wire, and dont think that i need it.
    The OEM Backup Camera gets power when tested in F-Cam app, but does not start (Power???) when putting the car in Reverse Gear.
    NOTICE: to see the links, delete the SPACE after //
  • I have updated the firmware to: 20250421
    MCU updated to: 4.16a
    No changes, the Camera does not start in Reverse Gear, only in F-Cam app.
  • It must be a software issue - on my old PX6 unit everything works fine.
    I tried the CB004 from my old PX6 unit on G13 - Camera still wont start.
    PX6, plug-and-play, works fine.
