Bluetooth audio dropping out in Android 11 Head Unit
  • I have a  Dasaita Carplay Stereo for Toyota 4Runner 2010 2011 2012 2013 Radio Upgrade Android 11 Head Unit GPS Navigation 10.25 inch Multimedia Music Video Player 4G 64G PX6 DSP Android Auto Bluetooth 5.0.
    Bluetooth  audio  dropping out    (interferance at  congested areas, traffic lights)   both during Android Auto Wireless connection via zlink and using only Bluetooth connection to bluetooth app.   Usually conecting via Spotify,  but issue is independent of source or phone.  Several different Pixels, 5a, 6a, 7a, 8  all exhibit the same behavior.
    I have seen other forum  where updating software  is recommended.   Can you please provide some guideance on recommend path forward.
    Photo of unit with MCU Build and Kernel details:
    Kiefer Headunit / Build / MCU / Kernel information
    Thank you for the assistance.
    John Kiefer
    johnkiefer66@gmail.com
  • @John Kiefer
    Order Number.
    Picture: Settings > About Machine > Model; Android Version.
    1) Ordered on September 17, 2022  Order# 112-5359650-8085867   amazon
    2) PX6  and Android 10 Model and android version.
  • @John Kiefer
    Thank you for your reply.
    Regarding to your issue, we suggest that you can try to update the firmware.
    MAX10 Version(20230302): Make Sure your unit is PX6 Andorid 10
    https://www.dropbox.com/scl/fi/wqwsxuh95e2lz7kttt2uk/MTCH_HA4Z_V4.09c.zip?rlkey=ki8vd6zsqvm9zadd34he0kfds&dl=0
    Specific Operation:
    Step1.
    Please download above update file via your computer/laptop firstly,
    then use the WinZip application to unzip the file.
    Step2.
    Step3.
    Step4.
    Step5.
    Please go Settings > System > MCU updates to start the update.
    Reference operation video:
    https://www.dropbox.com/scl/fi/szoeofthcmha1unhas6eh/Video-update-MCU.mp4?rlkey=vq742ltn5o6z4vidofrvdawlo&dl=0
    Thank You!,   I will give it a try and let you know how update changes the behavior.
  • @John Kiefer
    You are welcome :)
  • Support Team,    I am having an issue with the unit freezing.   I would like to update the firmware and MCU version.     Can you help me get the correct files and proceedure to follow ?
  • @John Kiefer
    Thanks for your contact .
    For this version, we don't suggest to update the system.
    Find a pin, press and hold the RST button for 15 seconds to see if you can enter the factory setup page, if you can, select factory reset and reboot the unit;
    NOTE: Make sure you press the RST button vertically and firmly, you should feel a slight press, or even hear a faint click. Please find the tutorial video below:
    https://www.dropbox.com/scl/fi/6mhzgijcv059wo2s9octl/G13-RST.mp4?rlkey=366exgktisqwb4ml1elqoge2u&dl=0
