G13(20250903):
https://www.dropbox.com/scl/fi/ygoiaoows0rwm1hicrcpl/update.zip?rlkey=fmhlg64li3ig1cki98phjp114&dl=0
@Chad Durden
Thanks for your message.
We have attached the new firmware&MCU, please check the update tutorial below then give it a shot.
System Firmware-G13-20250212:
https://www.dropbox.com/scl/fi/vlisvslcxnjaorf4bovg2/update.zip?rlkey=x0l7zfeg7rcf3lgey563d481m&e=1&dl=0
MCU-4.15a:
After the update, please go "Amplifier App > Delay > Auto > All" to move the crosshair to the center,
then see if all speakers have sound normally.
Same issue of no sound from rear speakers. 2011 4runner w/JBL.
@Nglayton
For the JBL system, please try to conntect the trigger wire .
G13(20250903):
②4.16g:
https://www.dropbox.com/scl/fi/61d69lkomwkf005tvgigb/hmcu.img?rlkey=emrb91895qodihn8f9ih27e7x&dl=0
@Support Dasaita "For the JBL system, please try to conntect the trigger wire ." --> The photo is too small, can you please show more detail about this trigger wire?
@Nglayton
Please check it,thank you
@Support Dasaita Yes- I checked it, there is a pending post I made with a picture of my harness. CB005-1X, and a question about why yours is labled CB005-2X, is there an update?
