How does the hdmi connection work? I plug in my hdmi and nothing happens. How do I change input?
@Drew Krupp
For your information, our headunit have a HDMI output port to connect HDMI cable.
Please make sure that you connection is correctly.
To further verify whether your HDMI device is compatible with our headunit, please provide your device product link if possible.
@Drew Krupp Hi Drew,i mean the what kind of HDMI equipment that you're having?Maybe you could should us the specification of the HDMI equipment.
@Drew Krupp Please try to power off the car then connected that cable to the screen to see how it work.
@Support Dasaita So pull the head unit out, unplug the HDMI, replug it in, and then turn the car on?
@Drew Krupp Yes,please have a try.
@Support Dasaita Tried that. Unplugged everything. PLugged in and what should happen? How do I change the input to HDMI?
@Drew Krupp It might be not support this type of HDMI cable.
@Support Dasaita Is there a recommended HDMI cable?
