2019 GMC Sierra 1500 + G13
  • Fresh purchase from Amazon, followed install for I0B factory headunit using CB115X harness and had issues with blowing the reverse light fuse that also disabled the rear camera.  Additionally, the provided speaker is really loud and would be erratic at startup if more than one alert existed (door open and no seat belt connected).  I may have to return if there is no solution.
  • @Jason Hodgins
    We'd like to know if you have tried to replace a new reverse light fuse.
    If YES, please tell uswhether the rear camera can work.
    About the speaker issue, please try to adjust the volume down:
    Settings > Car > Factory settings(password :126) > Voice.
    Amazon Order Number & Purchase Date.
  • Thank you for the response.  Yes, I replaced the fuse and it instantly popped again.  The order (111-9813712-1779420) was placed May 26, 2025.
  • @Jason Hodgins Hi Jason,
    Could you please take a video or some video of showing how you make the wiring connection?So that we could better confirm.
  • Here is a video of the wiring that I took tonight, https://youtu.be/wRuu9a3tck8.  I have verified that the fuse is blown once you put the vehicle into Reverse, I tried with the factory size 10 Amp and a 15 Amp fuse, both attempts resulted in a blown fuse before the video feed would appear.
  • All connections
  • @Support Dasaita, I just wanted to see if there is any update.
    Sorry for the late reply.we already reflect the issue to the engineer.If possible provide a pic of showing your OEM radio?
    Do you mentioned the factroy camera right? reverse light fuse will blown once you put the vehicle into Reverse?
  • @Jason Hodgins To better follow up your issue on time,shall we chat on email?
  • @Support Dasaita, I replied to the email, thank you.
  • Hello, I am still looking for support with this radio and have emailed the additional pictures that have been requested.  I am now outside of my return window and would like to get this issue resolved so that I can finally install and use this product as intended.
  • @Jason Hodgins
    Thank you for your time and patience in this matter.
    We're willing to send you a replacment . But in order to prevent the same situation from happening again, we would like to know the some data for your car.
  • @Support Dasaita, I am willing to exchange - please let me know what data you need so that we can find a device that works for our vehicle.
  • @Jason Hodgins No problem,we'll send you a return label
