No WiFi after update - cannot enable (not responding)
  • My unit 4G/Wifi option with reverse cam before stuck on black screen of death on boot was in the past:
    QCM6125 12 S10A_123 eng.hct.20230406.105233 EAU
    MCU: HCTGQ_HCT_V4.03_1
    Apr 4 2023 13:34:20
    I managed to enter to recovery mode and becouse lack of original software backup I put there:
    gmcu.img V4.12 first and update zst27_sc138_12_(20240513).zip ( I wiped flash of course).
    MCU: HCTGQ_HCT_V4.12_1
    Mar 13 2024 09:44:14
    QCM6125 12 S10A_123 eng.hct3.20240513.152630W
    The unit revived but now I don't have WiFi - the option is available in menu, but after I put it to on app suspends a little and nothing happens. Tried also gmcu.img V4.13 and gmcu.img V4.54
    The second observation - no other update than zst27_sc138_12_(20240513).zip boots correctly. Other G12's updates stop on the launcher's start and reset the unit. I always have to return to zst27_sc138_12_(20240513).zip to boot radio to normal operation, but there is no possible to execute command WiFi to on.(GUI can do it but hardware is not).
    The BT chip is FSC-BT825B V1.1 and in the factory settings works under FSC_BW124 setting option. Tries other BT options, but it didn't help for WiFi.
    IF I understand well the Wifi is in Fibocom unit becouse there is only antenna output. How to revive the wifi to have internet connectivity? Which firmware or MCU should be updated?
  • Dear Mik,
    ①G12 Version:Make Sure your unit is QCM6125 Andorid 12
    zst27_sc138_12_G12(20241126)
    ②4.12b MCU
    2.Format the USB drive before copying the Update.zip & hmcu.img  file to it, then insert it to the USB cable,and it will pop out the firmware updating tips on the screen.
  • @Support Dasaita I have MCU on  gmcu.img - is it safe to update from hmcu.img?  How to do it, because system update searches for gmcu.img?
  • @Mik Po Hi Mik,the MCU can be update to the latest,please don't power off the car when proceed the updating.
  • But MCU You linked is for HA4Z (hmcu.img) and it not compatible with my unit based on gmcu.img - it cannot be flashed (radio unit says it is not compatible).
  • @Mik Po Hi Mik,
    To ensure the specific solution for your car stereo,please provide us with your Order details(Including Order Number&Unit model&Version).
    please go to Settings>About machine and provide a pic of showing following version information:
    2.A clear photo of the stereo's MCU version.Thank you for your time and cooperation in advance, we look forward to your reply.
