Bluetooth connection sound is quiet
  • In g13 units the bluetooth connection sound is quiet. During a bluetooth connection you can turn the volume up to say 20. From now on during a phone call the sound will be at 20. Unfortunately this happens until the full unit is turned off. The volume returns to 12. It is similar with sim connections. When listening to music, the radio the volume is remembered. Please help.
    G13 order SP-DA6330 December 8, 2024.
    QCM6125 13 S10A_123 eng.hct.20250311.103730 EAU
    MTCHS_HA4Z_V4.16b_1
  • @Marcin Skwara Hi Marcin,
    Do you mean when the volume was set to 20,but the volume level can't keep at 20 when power off the car right?
  • Hello.
    Yes. The volume goes back to 12. Boot default volume set NO.
  • Hello What's up with the volume? It seems to me that in the old software the volume was remembered. Now, every time you turn off the ignition or the radio, it returns to 12.
  • On Settings - Vehicle - factory Settings (pass:126) you will find a Volume Setting that, as far as I know is the default volume for which the unit boots. You will find there system/Bluetooth and other different Volumes controlled by the MCU. Try to adjust the BT one to the desired level and check if it is memorized for when the unit makes a full boot (starting from power off).
  • @Marcin Skwara
    Thank you for your reply.
    Please go to Settings>About machine and provide the following version information:
  • @Marcin Skwara
    For this issue ,the  default volume  is 12.
    If the volume setting is higher than 12 before you shut down the device, it will revert to the default setting for the next meeting.
    If the volume setting is less than 12 before the shutdown, it will be saved.
  • Thank you for explaining how it works.
  • Hi. I don't understand why the default volume value is 12, since the factory settings have "default boot volume" disabled. This is a bug.
