Do you mean the belows AC information?
For this page, it only show the AC information . It can't change the AC directly
Hey guys , not sure if anyone else has had this issue but I just installed a new head unit and the A/c control screen pops up but when I press it on the screen it doesn't do anything.
I can't change the fan speed etc no matter how much I touch the screen
any help would be great thanks
I double checked all my connections ,
im also running the CB100 harness for my application
@Jonathan Albisu
Hey thanks for responding @Support Dasaita
the issue im having is a little more than just that now.
so the a/c control screen works intermitenly and what i mean by that is when i press the climate button the screen to adjust the A/C comes out but no matter what i press nothing can be adjustedand my a/c is stuck on the highest fan speed
another issue i have is when i put the car in reverse the guidance lines that help you reverse sometimes apear and sometimes dont
could it be that it needs a software update ? or wiring issue ?
So I was able to swap out one of the little boxes that came on the CB100 harness for the one that came with the radio and everything is working fine except I have no audio on car play phone calls
CarPlay music works perfect
CarPlay phone calls have no audio I can't hear them and the other person can't hear me.
@Jonathan Albisu
Thank you for your update.
Please notice to change the phoning audio setting to Carplay
If it is not luck,please go to Settings>About machine and provide the following version information:
@Support Dasaita I tried switching to car play for calls on the phone and still no audio
here Is the information requested
@Jonathan Albisu
Usually the built-in microphone is good enough for phoning calls, but we also included an external microphone just in case.
How is the volume for the bluetooth calls?
G13(20250620)
https://www.dropbox.com/scl/fi/jstacxfz4l9svgsjchmnr/update.zip?rlkey=hacqwnttcyb7wn7uoostpzwtv&dl=0
②4.16e:
https://www.dropbox.com/scl/fi/dxj9tjs9pnzv9actri0g9/hmcu.img?rlkey=g5hk0gsmuhaxqolypqf28occ8&dl=0
