17 civic type r a/c control
  • Hey guys , not sure if anyone else has had this issue but I just installed a new head unit and the A/c control screen pops up but when I press it on the screen it doesn't do anything.
    I can't change the fan speed etc  no matter how much I touch the screen
    any help would be great thanks
  • I double checked all my connections ,
    im also running the CB100 harness for my application
  • @Jonathan Albisu
    Do you mean the belows AC information?
    For this page, it only show the AC information . It can't change the AC directly
  • Hey thanks for responding @Support Dasaita
    the issue im having is a little more than just that now.
    so the a/c control screen works intermitenly and what i mean by that is when i press the climate button the screen to adjust the A/C comes out but no matter what i press nothing can be adjustedand my a/c is stuck on the highest fan speed
    another issue i have is when i put the car in reverse the guidance lines that help you reverse sometimes apear and sometimes dont
    could it be that it needs a software update ? or wiring issue ?
  • So I was able to swap out one of the little boxes that came on the CB100 harness for the one that came with the radio and everything is working fine except I have no audio on car play phone calls
    CarPlay music works perfect
    CarPlay phone calls have no audio I can't hear them and the other person can't hear me.
  • @Jonathan Albisu
    Thank you for your update.
    Please notice to change the phoning audio setting to Carplay
    If it is not luck,please go to Settings>About machine and provide the following version information:
    1.A clear photo of the stereo's Built Number.
    2.A clear photo of the stereo's MCU version.
  • @Support Dasaita I tried switching to car play for calls on the phone  and still no audio
    here Is the information requested
  • @Jonathan Albisu
    Usually the built-in microphone is good enough for phoning calls, but we also included an external microphone just in case.
    How is the volume for the bluetooth calls?
    Please update the Firmware & MCU to the latest version via the link below,here are some tips to help you get it done:
    G13(20250620)
    https://www.dropbox.com/scl/fi/jstacxfz4l9svgsjchmnr/update.zip?rlkey=hacqwnttcyb7wn7uoostpzwtv&dl=0
    4.16e
    https://www.dropbox.com/scl/fi/dxj9tjs9pnzv9actri0g9/hmcu.img?rlkey=g5hk0gsmuhaxqolypqf28occ8&dl=0
    2.Format the USB drive(FAT32 Format)before copying the Update.zip hmcu.img file to it, then insert it to the USB cable,and it will pop out the firmware updating tips on the screen.
