@Mcgyver83
It is the latest firmware for andriod 11.
Have you tried to remove and reconnect the CANBUS?
@Mcgyver83
@Support Dasaita yes, last one available for PX6 android 11.
I'll try to reconnect Canbus plug, I have to find a time to do it.
@Mcgyver83
Thanks for your time
@Support Dasaita I remove the unit, unplugged all connectors and re-plugged all.
Now with latest firmware for PX6 android 11 from this forum I have SWC and Android auto wireless working.
All connectors were inserted, I don't know what happened. I also removed the power connector so I physically restarted the unit; maybe this helped.
Luckily now both features work fine.
@Mcgyver83
Thank you for your updates.
It’s great to hear that everything’s working well finally!
@Support Dasaita Yes, I'm happy that now it works.
I have only to suggest to use stronger clip to keep the unit in place.
Pins reusing OEM red clips are good, smalle black clips embedded in the Dasaita frame are thin and break easily when removing the unit.
Is it possible to buy the black frame around the display, PX6 unit?
