Toyota Corolla 2015 Wireless Carplay Not Connecting
  • I have a Dasaita for 2015 Corolla, I upgraded to the iPhone 17 Pro Max, got it hooked to Carplay and everything was working as it has been for years. I decided the phone was too big and got the iPhone 17 Pro instead. I can not get the wireless carplay to work anymore. I have tried forgetting the bluetooth, wifi, and carplay connection from my phone. I have reset the entire headunit to factory setting. Nothing is working. The bluetooth will pair but that it, it never transition over to the Carplay connection. The wired Carplay still works as it should but got this radio because of the wirless. Do I need to update the software? Is there something I'm missing? My unit spec are below:
    Model - PX6
    Android Version - 10
    Build number - rk3399-userdebug 10 QQ2A.200305.004.A1 eng.hct.20200915.180332 test-keys
    Kernel version - 4.19.111+ (#2266 Tue Sep 15 15:49:09 CST 2020)
    MCU version - MTCE_HA_V3.62_1 (Sep 14 2020 10:29:09)
    CPU - Dual-core Cortex-A72 @ 1.8G Quad-core Cortex-A53 @ 1.5G
    Memory - 3841 MB
  • @Courtney Williams
    System Firmware-MAX10-20230302:
    https://www.dropbox.com/scl/fi/mwzw2q4ojdfoz3mnp0i08/update.zip?rlkey=np70fog84q4mmy903xsofdz13&st=znaujgwo&dl=0
    Format USB drive to FAT32 Format.
    Copy the file update.zip” to the root directory of USB drive.
  • @Support Dasaita I preformed the update and wireless CarPlay did connect but now it disconnects after 3 mins and may or may not connect again. Wired CarPlay is now also disconnecting and to reconnect forget and restart both my phone and the head unit. It there anything else I need to do?
  • @Courtney Williams We are wondering if your IOS system is IOS 26+ or not, if so, we are sorry that MAX10 should not be compatible, you may need to update to Vivid10 or the public Android 10 version.
    Here is the firmware Vivid10(20250401):
