try removing your Google account, and then add it again
Thanks for the reply, but unfortunetly it did not work. I think I may need to do a factory reset if I can't disable this feature. There is a menu for it somewhere because I was in it when I set up the pin code, but now I can't find it. Hopefully, another person has dealt with this issue or hopefully, Dasaita will have a solution.
@Mochi Kiwi Thank you for the suggestion.
@Support Dasaita Thank you! That worked (the factory reset)! There is no more PIN being requested when the unit starts up. So far everything appears to be working after the factory reset.
@Joseph Rohan @Support Dasaita I need to do this as well but will I lose CarPlay/ZLink with a factory reset? I've read of some people doing a factory reset and both programs being gone after.
@Joshua Bunting
If it doesn't display the Zlink App after the factory reset, please try to do as follows:
Settings > Car > Factory settings(password :126) > App > CarPlay > Zlink > Apply > Exit > Reboot.
