To prevent upgrade errors, we have removed the public download links for MCU firmware. This is because required versions differ across models (e.g., G13, Vivid11) and even production batches.
If you are experiencing CAN Bus issues, steering wheel control problems, or other MCU-related malfunctions, please contact our support team directly. We will provide you with the correct firmware for your specific device.
Thank you for your understanding.
Hola. Tengo el G13 y necesito el MCU correcto para mi Toyota 4runner 2015 con llave Inteligente.
@Paulo Villalba Could you please let us know the issue so that we could check if MCU update is needed or not?
Salve mi potreste dire l'ultimo aggiornamento mcu per il px6 max10 ?grazie
@Vittorio Menconi Hi there, we do not suggest MCU update if the radio is working in good condition.
Hi, I have this model PX5: MTCE_HA_V3.40db_1.
The issue that I have is that the Radio stopped working. Everything is fine, but I cannot listen to the radio.
A new MCU could solve this? If yes, can you help me with this?
@Support Dasaita non mi va assolutamente la radio..
@Marcelo Eguino We are wondering if you have already proceed the factory reset or not, we don't have newer MCU for PX5 currently.
If stil no luck after the factory reset, it may be hardware issue.
Andriod version - 13
Build number - qcm6125 13 s10A_123
MCU version - mtchs_ha4z_v4.14e_1
Can I update to mtchs_ha4Z_v4.16x?
Salve dove trovo aggiornamento mcu
Hello! Can sand me an updates for:Model:px5
Vers
px5-userdebug 8.0.0 OPR5.170623.007 eng.hct.20181210.165451 test-keys
Ver МСU
MTCE HA V3.10_1
Apr 11 2019 10:14:06
Serial n:
799704E6A1AA6170
Proc
8core 64-bit CPU Coretex-A53 a 1.5G
@Keith Guin You could update to MCU(4.17a):
1.Download above update file via your computer/laptop.
2.Format USB drive to FAT32.
3.Copy the file “hmcu.img” to the root directory of USB drive.
4.Insert USB drive into the unit via USB cable.
Go "Settings > System > MCU updates" to start the update.
@Nino Liga Please go to Settings > About Machine and send us the Build Number and MCU version.
