@mochiii
Max10(20230414)
@Brian B
Could you please confirm whether you have installed an aftermarket amplifier with the head unit?
If yes, please let us know:
*The brand and model of the amplifier
*Whether it is an active/powered amplifier or a passive setup requiring external amplification
*Whether you are using the RCA outputs, optical output, or both
This information will help us determine whether the low output is related to the head unit settings, firmware, or the amplifier setup.
We are running the optical output to a aftermarket DSP processor (JL audio TWK 88). We tested the signal with an audio measurment system and found it to be unstable and have substantial disortion over volume 20. Older versions of this firmware in systems we have installed in other vehicles with this head unit did not have this issue. We tested the amplifier in the headunit and it is funtioning as expected on the speaker outputs but they will not be used.
Hello!
Could you send me the latest software updates for my Android head unit?
Here are the current technical details of my device:
- Processor / Platform: Qualcomm Snapdragon 665 / QCM6125 (S10A)
- Current OS version: Android 12
- MCU Version: HCTGQ_HCT_V3.99_1
Could you please provide me with the download links and installation instructions for:
- The latest available Android 13 (or a later one) firmware update compatible with this device.
- The latest MCU update for the HCTGQ platform, if a newer version than V3.99_1 is available.
Thanks a lot!
Hola. Tengo un problema con mi dasaita. Llevaba ya un tiempo que se reiniciaba sola. De repente la radio dejó de escucharse. Funciona todo pero, solamente la radio, no se oye. Todo lo demás si se oye. Se me perdieron los canales de la radio guardada. En la radio los botones de pasar de emisora al pulsar, emite sonido pero no cambian. En los mandos del volante, si me funciona al cambiar de emisora, pero al dejar pulsado para que busque automáticamente, no funciona tampoco. He reseteado, he reiniciado de fábrica. Desconecté durante un tiempo la tablet de la bateria del coche y de ninguna forma se soluciona.
los datos son:
modelo PX5 (1024X600)
número de serie: D1C1556E27A8D2F1
version de android: 10
versión de MCU: MTCA_HA_V3.57_1
versión del kernel: 4.19.111+
#2118 Mon Aug 24 173101 CST 2020
CPU:Octa-core Cortex-A53 @ 1.5g
¿Es posible que realizando una ctualización del MCU, que esto se solucionase? y si esto fuera posible, ¿me podrían facilitar el MCU correspondiente o superior para mi dasaita?
Muchas gracias de antemano.
Un saludo.
@susisusimc2000 Due to the advancement of hardware and software technology, the hardware performance and software compatibility of this model are gradually unable to meet the requirements of the new system. In order to ensure user experience and device security, the model you purchased has stopped system maintenance and will no longer receive maintenance and updates.
@biketrial666
If your unit is currently running smoothly, we would actually recommend not performing the update. Car navigation systems generally come with very stable software, and updates are usually not necessary unless you are experiencing specific issues.
Please feel free to let us know if you have any questions. We are always happy to help.
Hello! Can sand me an updates for:
Model: px5
Vers : px5-userdebug 8.0.0 OPR5.170623.007 eng.hct.20181210.165451 test-keys
Ver МСU: MTCE_HA_V3.06_1 Jan 24 2019 20:11:03
Serial n: D5F6F085A1A91708
Proc: 8 core 64-bit CPU Coretex-A53 @ 1.5G
RAM 3891 MB
@Support Dasaita Having issues with my G13 going blank, screens goes blank. I can still hear the radio but the screens shuts off. is there an update.
Hi, I have a PX5 head unit with a screen that randomly freezes when the rear camera is activated. Sometimes it happens immediately after shifting into reverse, and other times after a few seconds. The image just freezes, looking like a still photo of the last frame from the backup camera.
Model px5(1024x600)
Android 8.0.0
Security pacht october 5 -2017
px5-userdebug 8.0.0 OPR5.170623.007 eng.hct.20181128.114616 test-keys
Ver МСU
MTCE _HZC_ V3.00b_1
Dec 1 2018 10:11:25
Serial n:
D105B81827A8CFE9
CPU
8core 64-bit CPU Coretex-A53 @ 1.5G
KERNEL VER
4.4.93+
rocky@r930 #41
Thanks in advance, I really appreciate your help
@TIZ0CC Hi ,please record a video of the radio issue to our support email:
support@dasaita.com
@gdjmunoz2 @myforpost
| https://www.dropbox.com/s/f2gpqa31qp4gx5t/ha_px5_8.0_ota%2820190731%29%E5%8D%87%E7%BA%A7%E5%8C%85.zip?dl=0 |
Steps:
1.Download both files on computer.(keep names & zipped).
2.Copy file to a FAT32 USB drive (root folder).
3.Insert the USB drive into the device→ follow prompts → tick "Wipe data and format flash"
@Support Dasaita Hello, thanks for your reply. You mentioned downloading both files, but I only see one. Could you send the second one, or was that a misunderstanding?
Best regards
