Hi Support,
I've downloaded the latest Firmware ( HA3_rk3399_10.0_ota(20230803) ) an made the Update via USB-Stick.
After the Update Bluetooth isn't activated anymore and I can't avtivate it.
What can I do to get my Bluetooth working ?
Hello @Jens Schwoll,
Please go Settings > Car > Factory setting (Password: 126) > App > switch the BT to the following one and see if the bluetooth could work or not:
1.FSC-BW124
2.WQ RF210
3.WQ-BC6
4.SDIO-AUTO
I have the same problem.
Besides those mentioned, I've tried (almost) all BT models, and none of them have paired successfully with the phone that previously (before the update) connected to the PX6.
I say "almost" because the last two on the list, despite being selected and saved like the others, weren't saved. After re-entering the system settings, a different model was selected.
Interestingly, when the FSC-BW124 was selected, the BT icon is completely inactive.
@Robert To resolve the Bluetooth connection issue, please follow these steps carefully:
On both your phone and car system: Forget or remove all previously paired Bluetooth devices from the settings.
On your car system: Go to Settings > Apps > Clear Cache of Bluetooth application.
On your phone: Perform a network settings reset (this will clear Wi-Fi and Bluetooth settings).
Re-pair: After completing the steps above, restart both devices and attempt to pair them again as a new connection.
This process will establish a fresh connection and may resolve the issue.
Sorry for answering so late, thx to my daughter the car wasn't last weeks.....
I got back to an older Firmware I've downloaded 3 years ago after buying the radio.
Bluetooth works without problems, in your mentioned settings it's the FSC-BW124
Tried again updating to the latest version, settings are still FSC-BW124, still can't activate bluetooth.
So I'm back to the older Version
Sorry for answering so late, thx to my daughter the car wasn't available last weeks.....
@Jens Schwoll
It is great to hear that it works.
If possible,we appreciate it if you could share the resolution here.
Thanks for your time.
