SIM recognized, still no data
  • Issues #1.
    Unable to connect mobile hot spot, Z-link immediatly takes over WiFi and disconnects phone data. I have to turn off carplay in settings > general > carplay > car kit, and that didn't always work. 50/50 chance Z-link would still try to connect and take over wifi.
    Issue #2.
    The unit would show hot spot/bluetooth tethering was on, but BT Tethering will not turn on, it might toggle to the on position but would immediately revert to the off position. The unit is unable to connect to mobile data thru BT, even though factory settings is set to on.
    Issue #3.
    After reading almost all posts about SIM issues and workarounds, though not much on the G13 08 Toyota Tundra version or V2, but I decided to give it a go. No pins on the SIM, it's recognized by the system, shows up on the Home Screen as if it is connected to data, but does not provide mobile data.
    Purchased 11/9/25, order #SP-DA754 on Dasaita website, I believe it went through an update after installation, and connected to home wifi.
    Network set to LTE, Factory Settings > other > SIM card voice call - YES, APN looks correct, at least with the Verizon SIM, tried AT&T also and it was recognized too but would only show a temperary not in service in SIM setting.
    Build - QCM6125 13 S10A_123 eng.hct.20250903.190343 NA-V2.1
    MCU - MTCHS_HA4Z_V4.16F_1
    Would be great to have this SIM card working, as the upgrade I thought I was getting is pretty much the PX6 Vivid 11 I was trying to replace.
  • @David Hollabaugh
    1. Please go to CarPlay settings and turn off the Background connection.
    2.You could show us video to demonstrate the situation so that we could better confirm.
    3.When you plug in the SIM card, you must restart the Dasaita unit: settings > car settings > factory settings and put "hctreboot" as password.
