Intermittent sound
  • I lose sound from all speakers when driving - randomly. I suspect this is a physical issue & could be at the wireharness used to bypass the internal amp. Will driving it will eventually come back. Has anyone else experienced this? My setup is below. When it works - it sounds fine.
    -2007 Toyota Tundra Limited (w/JBL)
    -G13
  • @James Johnston
    Thanks for your contact.
    1. Find a pin, press and hold the RST button for 15 seconds to see if you can enter the factory setup page, if you can, select factory reset and reboot the unit;
    NOTE: Make sure you press the RST button vertically and firmly, you should feel a slight press, or even hear a faint click.
    2. Please try to disconnect  and reconnect the cables.
  • Okay thank you. I will try this today and monitor.
  • Hi,
    I noticed if I touch the connector "ZEOS-A78291T-021" you can hear static coming through the speakers and you will lose sound. I suspect maybe some of the terminals are bad on this connector.
  • @James Johnston
    Hello,please send your order ID to this email to get a help: support@dasaita.com
    Thanks for your time and cooperation.
  • Will do thanks
