Recently installed a QCM6125 dasaita radio in my 2019 Toyota Tacoma and the audio cuts out after awhile. When reading other troubleshooting steps from other users it seems to be a common issue. Attached are the specs for my radio after installing a firmware update from your website. It seems the CANBUS is getting hot. What should I do next?
@shevlisp
Please refer to the update tutorial provided below and follow the steps to perform the update.
Thanks in advance.
System Firmware-G13-V1-20260811:
https://www.dropbox.com/scl/fi/p5ocvu6u9o7x5ubgq765j/update.zip?rlkey=f88uayb0ezmkjn6qzqcz0ki3v&st=mhvj0vvb&dl=0
MCU-4.18a:
https://www.dropbox.com/scl/fi/amw3k7mtkkxeb6zlbaxet/hmcu.img?rlkey=6g0yol3jrqa5s157fono6qv7s&st=4cf4ksmj&dl=0
Steps:
Download the above update file on your computer or laptop.
Format the USB drive to FAT32.
Copy both “update.zip”&“hmcu.img” to the root directory of the USB drive.
Plug the USB drive into the unit via USB cable.
An update pop-up window will appear automatically.
If not, manually go to "Settings > System > System updates / MCU updates" to launch the update.
Ensure the option "Wipe data and format flash!" is checked.
Reference‑Operation Video:
