Black screen/ no power (vivid 13) 2018 tacoma
  • Just installed this unit in my 2018 tacoma everything worked fine when I plugged everything in. But as soon as I go to install it into the dashboard everything went black and it won't turn on. I check connections many times and they are solid. I cycled through my headlights to see if the knob light turns on and nothing. I pulled my negative lead on my car battery and waited 20 minutes then tried to power on and nothing. I checked the fuse on the head unit and its still good. I checked the fuse under my steering wheel and its still good. Ive tried doing the rst button many times and no luck. Im going to check the fuse in my glove box and if thats still good im going to check the pins with a multimeter to make sure im getting 12v. I will also try to do the rst while turn power to ACC to clear the cache. Hopefully i get this to work. Any help with troubleshooting would b greatly appreciated. Thanks
    I ordered off amazon and my order number is Order # 114-9669203-2942629
