Is there a way to fine tune the radio settings of the NXP6686 radio chip in the G13 units? For example, adjust gains and signal reception. My radio signal in the G13 is much weaker in the same areas as my factory radio. I've checked the antenna connection. I'm using the same OEM Antenna. I've checked and tried both USA radio setting in the factory settings menu.
Currently on
MTCHS_HA4Z_V4.16g_1
MCU version.
@Paul V
Sorry for there is no related radio settings.
Regarding to your issue, please try to disable RDS function to see how it goes:
Settings > Car > Factory settings(password :126) > Other > Radio RDS > Off > Apply > Exit > Reboot.
If no luck, please provide the following information:
Picture: Settings > About Machine > Build Number.
Thanks in advance.
hello, it seems like several peole have the same issue. I am having the same reception issues as well with Not recieving any radio stations. I have the 13 as well, and have attempted to turn on and off the RDS and tried both location settings, America 1 and 2 with no luck. I have also double checked the antena is connected and replaced the exterior antena as well still no luck.
Are there any fixes for this?
QCM6125
version 13
kernel 4.14.190
MCU - MTCHS_HA4Z_V4.16f_1
